Eps light came on
Old Aug 27, 2009 | 04:37 PM
Lttakas's Avatar
Default Eps light came on
Ok so my powersterring works only when the car is cold,but after I drive it and try to start it back up the eps light comes on and I don't have powersteerting any more.any one know what's going on?could it be from overheating issues?
Old Aug 27, 2009 | 05:20 PM
CKit's Avatar
Need more information. What "overheating issues" and what have you modified on the car?
Old Aug 27, 2009 | 05:42 PM
Lttakas's Avatar
Sorry about the lack of info my car is stock I was just saying that it seemes like the powersterring goes out when the engine bay gets warm
Old Aug 28, 2009 | 11:00 AM
s2000_sk's Avatar
mine does the same except it only works once the eps has warmed up. check the wires leading to the eps.
Old Aug 28, 2009 | 11:10 PM
neeman77's Avatar
Does your spedometer ever drop to zero randomly?
Old Aug 29, 2009 | 03:19 PM
ronnuke's Avatar
If your speedo drops to zero your EPS will fail and not render assistance, since assistance is speed dependant. Mine was caused by a failing/failed yellow jacket speedo calibrator I installed to adjust for my new rear end gears. I tried first the vehicle speed sensor which was not the problem, nor was it a ground issue. I now have a new Yellow Box speedo calibrator working flawlessly and no more issues with speedometer dropping to zero.
Old Aug 29, 2009 | 03:29 PM
neeman77's Avatar
I had the same problem with the yellow jacket, that is why I asked lol.
Old Aug 29, 2009 | 05:34 PM
Lttakas's Avatar
Dam this suck I get a workout every time I need to drive my car.so anyone has a fix for it?
Old Aug 29, 2009 | 05:46 PM
Lttakas's Avatar
And yeah my speedomiter never drops to zero.the powersteering just stops working when the car warms up.like today I had to drive to the gas station that was 3m away the powersteering worked fine till I had to start up the car again my eps light came on and I was driving with no power steering.could bad aligment cause the powersteering system burn out?
Old Aug 30, 2009 | 12:55 AM
neeman77's Avatar
No, but you can get the code read for why the EPS light is turning on and that will lead you to the problem. Start by checking all the connectors on the steering rack.
mikefifth
Oct 21, 2014 02:55 PM
s2konroids
Mar 28, 2011 05:01 AM
JPRICE!
Mar 25, 2011 04:09 AM
goldenfri
Oct 15, 2007 01:31 PM
honda9krpm
May 10, 2006 03:54 PM
