Spods for Subs?
Old Jun 17, 2005 | 06:58 PM
Saki GT's Avatar
Default Spods for Subs?
Question, has anyone ever considered putting speakers in SPods to act only as subs? I'm looking for ways to boost bass in the cabin short of installing a full-blown sub...
Thanks,
Old Jun 17, 2005 | 07:04 PM
jwa4378's Avatar
That would be LOUD...imagine...a sub pointed right at your head....WOW
John
Old Jun 17, 2005 | 09:42 PM
jasonw's Avatar
John
There is always the gain setting... And for the record, bass is omni-directional. The only difference aiming the sub makes is vibration and reflection of sound waves(can be good).
Sounds like an interesting idea as long as the SPODS can take at least 6" and are air tight with little to no flex...
Old Jun 18, 2005 | 12:23 PM
Saki GT's Avatar
Okay, so I need speakers that are at least 6" and I'll need to seal up the Spods as best I can? I thought the biggest speakers I can get into the s-pods are 5.25", wo do you think a pair of them will suffice?
As for loudness, there's gain, plus I was thinking of just wiring the Spods as my rear speakers from the HU, so I could quickly adjust their volume/throughput through the fader without having to mess with adjusting a trunk-mounted amp.
I want to have only components up front, and something for bass, but it doesn't need to be earth shattering, just nice and rich when the top is down.
Old Jun 18, 2005 | 02:03 PM
formulaofsuccess's Avatar
a HU amp supply will not be enough to generate any amount of "bass" for you. you'll definitely need to amp them and then control their output through a sub volume control capable HU
Old Jun 18, 2005 | 07:28 PM
c13's Avatar
c13
Save yourself the time and headaches, put a small sub in the trunk. They don't take up that much room and will give you the nice "top down" bass fill you want.
Old Jun 19, 2005 | 08:32 PM
hukares's Avatar
You could go with the Focal 5WS. Not that I agree with the idea of putting the speakers there nor do I know the quality of the speaker. But, it is only a little bigger than 5 1/4", if I remember it's 5 3/8". Something you could look into.
Old Jun 19, 2005 | 08:37 PM
hukares's Avatar
I don't agree, but that's because I was one of the people that went an alternate route. You might have read it in some other posts about subs under the conv. top. I don't have any pictures. FWIW, I will finally see my car again at the end of this week and will get some pictures then. I'll probably just put them in the "show off" so stay tuned to that in case your interested in something similar.
Old Jun 20, 2005 | 12:46 PM
marks2002's Avatar
Sorry it took so long for me to respond...I took the weekend off
I have installed 6.5's in S-Pods before, so this could be done. (It just didn't make snese for production.)
Sealing the chamber would be easy with RAAM Mat, or Dynamat.
Possible problems:
Will there be enough air volume in the sealed roll hoop chamber?
6.5's require the speaker mounting holes be cut so big that very little surface area is left for hardware attachment. The method I currently use to attach speaker grilles will need to be modified.
The 6.5 Pioneers I played with had to be trimmed to fit. I suspect all others will too.
bartonbeau
Apr 15, 2018 01:18 PM
S2000Matt
Jun 5, 2012 01:03 PM
Gatsbee13
27
Sep 22, 2010 08:52 AM
Kyushin
Apr 17, 2004 08:01 AM
BlkMagic
Aug 24, 2003 05:42 AM
