srs light
Old Mar 18, 2012 | 03:39 AM
4urmrs's Avatar
Default srs light
after resetting the srs light it went away, but after taking the car for a spin not even 40secs the srs light came back on. so i reset it again later and took the car out for another spin same shit happens. i checked all the wiring make sure its plug in properly. is there anything else im forgetting?
Old Mar 18, 2012 | 10:20 AM
TPhong's Avatar
What year is your S, and have you replaced a part of the SRS recently?
Old Mar 18, 2012 | 10:25 AM
T-Smac's Avatar
Any other lights on? Brake light for instance? Or CEL? Be careful with SRS wiring (yellow connectors) Some static electricity and you could set off your airbags.
Old Mar 18, 2012 | 06:51 PM
4urmrs's Avatar
its an 01 model havent replaced anything at all, no other lights on the cluster come on just srs light.
Old Mar 18, 2012 | 09:58 PM
T-Smac's Avatar
You can pull the ABS Code by doing the following:
Jump pins 9-4 in the ODBII connector with a jumper wire. MAKE SURE IT IS PINS 9 AND 4.
Turn the ignition to the ON position
Look at the ABS light
Count the number of Long blinks
Count the number of short blinks
The blinking will pause and restart until you turn off the car.
Turn off the ignition
Remove the jumper wire
Add the long at short blinks together (long blink = 10, short blink = 1)
Post the blink code total and we can tell you what it means.
Long Blink = 10
Short Blink = 1
Old Mar 19, 2012 | 09:54 PM
4urmrs's Avatar
doesn't seem like it has the obd2 connector any where in the car, looked in passenger/driver side nothing at all. search around before seems like others are saying the same thing, it don't exist at all for RHD s2ks in Australia.
is there anyway around it? like scanning codes off the srs ecu?
Holeshot121
Sep 11, 2021 12:17 PM
gtman
Mar 23, 2018 12:09 AM
plizzat
Dec 15, 2016 03:01 AM
mikefifth
Oct 23, 2014 09:23 AM
kaansahbaz
Oct 2, 2014 04:22 PM
