SRS Light and accessory questions
Old Nov 20, 2016 | 05:03 PM
plizzat's Avatar
Default SRS Light and accessory questions
Hey s2kers,
My srs light has been on a long on my ap1. I'm not sure how to reset it but from what I've read it's a complicated process. Can anyone shed any light? Also my accessory plug is putting out low voltage 1.8 vs I think 12? Does anyone have any idea why there would less voltage coming through the plug? Thanks guys.
Old Nov 21, 2016 | 02:51 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Nothing complicated about it.
Yellow 2 pin connector in fuse block with 2 green wires:
-jump connector, turn key on
-as soon as srs light goes off, remove jumper
-as soon as light comes on, jump connector
-as soon light goes off, remove jumper
-watch for double blink of srs light (reset complete)
If the srs light comes back on after double blink, then you have a hard fault that needs to be fixed first.
Old Dec 14, 2016 | 09:08 AM
plizzat's Avatar
Thanks,
Can you elaborate a bit on what you mean by jump connector? Thanks.
Old Dec 15, 2016 | 03:01 AM
Billman250's Avatar
Top Answer: 1
Jump connector=make a connection.
mikefifth
Oct 23, 2014 09:23 AM
mikefifth
Oct 21, 2014 02:55 PM
OVER 9000!
Nov 19, 2013 08:12 AM
4urmrs
Mar 19, 2012 09:54 PM
