Stealth install for jl 300/2
Where can I put this?? Will it fit in the wheel well of the spare tire?? Dont wanna take out the spare tire as for an emergency. Will it fit under the seat?? Pix would help, thanks!
Even a great amp like a JL needs some ventilation, and to be mounted right side up. These amps are designed so the heat rises up off the heatsinks on the top. You may want to at least flip your amp over. I have seen some pretty nice lookin installs more centered in the trunk.
Put it on the wall behind the passenger seat - cooling fins up.
You will loose a couple clicks of seat adjustment, but it will work fine even with the seat pressed up against it.
I have been running a JL 500/1 like this for 3 years and no issues.
The install was done by a local audio shop and I hadn't really even thought about the right side up aspect.
I would just follow up on it.
John
The cooling fins are on one side - not sure if it really matters on the JL slash amps if they are upside down as long as the fins are clear.
Would probably have some heat soak on the PCB though.
Originally Posted by jwa4378,Feb 10 2006, 09:29 AM
If this amp was not designed to be installed upside-down, that could void the warranty for "improper installation."
