stereo died
Old Dec 2, 2008 | 03:08 PM
hariku821's Avatar
Default stereo died
I bought a new pioneer hu when i got the car. The car already had aftermarket speakers tweeters and an infinity 7520a amp. Everything worked fine after i put in the new HU except the tweeters didn't work but that wasnt really a big deal to me.
Last Saturday the hu was loosing power and shutting off after i hit a bump then it went out completely. I checked the amp and the ground wire had come loose i tightened it up and all was fine. Monday the same thing started happening but the ground wire is secure and i cant find any other problem. I checked the cable going to the battery and the amp but i cant seem to figure out whats wrong... Currently the hu will not get any power what so ever..
Any help/ideas would be greatly appreciated
Old Dec 2, 2008 | 03:44 PM
G's Avatar
G
Have you checked the wires going to the HU? Also check that the plug is snug in the back of the HU.
Old Dec 2, 2008 | 05:40 PM
Cubs2k's Avatar
If you hooked the HU up with a harness that mates to the oem plug, then you'll want to check the fuses under the dash. The one to check is the accessory #9 10 AMP fuse that seems to pop for a lot of people.
The quick way to test this is to plug something in the lighter/Acc socket.
Also your HU may have fuses too.
Old Dec 2, 2008 | 05:49 PM
hariku821's Avatar
i just checked them.. the main conection was not loose but i fiddled with the wires and it started working agin.. but if it gets bumped a little it stops and i have to touch them agin..
could it be a bad wiring harness?
Old Dec 3, 2008 | 04:31 AM
Cubs2k's Avatar
How were the wires put together?
Personally, solder and shrink wrap is the only way to go.
ar10
Apr 19, 2015 08:37 AM
manystyles
Feb 3, 2015 03:36 PM
Capcitys2k
Sep 2, 2009 12:58 AM
black s2k
Jan 1, 2006 04:58 PM
jojipoji
Apr 7, 2004 08:05 AM
