Audio was intermittent, then cut out completely help..
Old Apr 18, 2015 | 08:58 AM
ar10's Avatar
Default Audio was intermittent, then cut out completely help..
My S2000 I bought from someone came with an aftermarket headunit, appears to be wired with a streetwires power station amp kit. A while ago, the radio audio would intermittently cut on/off. Then one day, there was no audio at at. I just replaced the headunit, so I think that's ruled out as the problem. I checked the radio fuse, it seems to look ok. The streetwires fuse by the battery looks ok as well. Anyone have suggestions on what's causing the issue? Unfortunately I know very little about how audio is wired, was trying to avoid a costly trip to a shop if it's something I can fix at home.
Old Apr 19, 2015 | 08:37 AM
oth's Avatar
oth
You mention an amp wiring kit, but you don't mention whether there is an external amp installed.
If there is, could be loose wiring to the amp or a failing amp.
If there isn't, if the power to the headunit stays on, but the sound stops, the problem likely
lies somewhere between the headunit and the speakers. A loose wire would likely cause only one
speaker to cut out, but a wire shorting out might cause the headunit (or external amp) to go into
protection mode cutting off all sound.
Capcitys2k
Sep 2, 2009 12:58 AM
crdcz03
Jun 25, 2009 06:22 AM
DDuds2k
Aug 13, 2007 05:13 PM
Kibro
Sep 12, 2001 05:32 PM
virtualtom
Jun 6, 2001 08:13 AM
