Stock Stereo and Computer CD's
Old Nov 17, 2000 | 09:01 PM
Gunfighter73's Avatar
I tried playing a music CD that I burned from some mp3's but the cd player just spit it out. My home stereo and my Pioneer in my other car play the cd with no problems. Anyone else have the same experience?
Old Nov 17, 2000 | 09:10 PM
edasaurus's Avatar
I sometimes have trouble with the CDs I burn too. I never had a problem with my pioneer changer.
-Ed
Old Nov 17, 2000 | 09:38 PM
BlackPearl's Avatar
If this happens with all your CDR's maybe try using a different brand of CDR...
thicknesses, though minute may vary and be enough to JOG your cd player back into action allowing the laser to properly read the new types of CDRs you use...
and yes it MUST be a closed session CD...
btw, does it work on ANY? of the type of CDR's you 're currently using or just that one?...Also, don't know what speed you're burning at but I wouldn't go above 2x...
maybe ya might have scratched the TOC area on the inside edge otherwise... just another idea...
Old Nov 17, 2000 | 10:31 PM
Schatten's Avatar
I've seen a lot of problems with cheaper CDR's, as previously mentioned, try a different brand. The most successful are with the Sony's.
I have some more info about CDR's specifically with brands manufacturers and where they are all made, etc. Bug me personally and I'll post this info up when I'm not so tired like I am right now. =)
Old Nov 18, 2000 | 04:49 AM
Bieg
Guest
Posts: n/a
Make sure you are using a good burning program like "Toast" and that the song files are saved as "Sound Designer II" files. Also make sure you are burning it as a music CD.
I have never had a problem with the S2000 CD player and CDRs. Many DVD players on the other hand do not like CDRs.
Old Nov 18, 2000 | 05:21 AM
1Y2KS2K's Avatar
Check that you are burning the music on to CD-R media and not CD-RW. I'll mention this quote from my Easy CD Creator 4 manual:
"CD-RW media can only be used in CD-ReWritable drives or newer MultiRead CD-ROMs. You cannot play CD-RW in most home or car stereo CD players." The optimum word is the last sentence is MOST. This infers that the CD will possibly play in your other systems, but not on others (such as the car system).
Make sure the CDs are CD-R. And also read the program instructions to make sure you are using a compatible media format. There are a lot of music format variables you can use or change. It's important to use the right ones for successful reading.
Old Nov 18, 2000 | 06:28 AM
Mapman's Avatar
This is gonna sound stupid, but are you sure that you wrote the CD? I had the same problem with one of my CD-R's recently. When I checked it back in the rewriter drive, it had nothing on it. In one of my endless experiments, I had stupidly checked the "Test Only" box when I was setting it up to record. I brought up the songlist again & did it right and all was well with the world. I haven't made a coaster yet!
Mike
Old Nov 18, 2000 | 06:43 AM
Thanks for the help everyone. I was using a fairly cheap CDR so maybe I'll try it with a better brand. I know I was doing everything else right because they work in my other cd players.
Old Nov 18, 2000 | 10:13 AM
S2K_CLS's Avatar
I use the Memorex brand and have never had a problem in ANY car.
Consider the brand, and like said above, make sure its a CD-R, not RW.
One last thing, on certain CDs I made, the label I put on them caused them to be spit out by certain car players...
Old Nov 18, 2000 | 12:06 PM
MacGyver's Avatar
Slightly OT...
Don't ever buy Imation CD writers. I purchased a 4x4x20 CD-RW about a year ago and have had NOTHING but problems with it. To date, I have YET to create anything but coasters. Long story short, called tech support and they were not only EXTREMELY rude and short tempered, they proceeded to blame the situation on me, the computer and enything else they could think of EXCEPT themselves.
Needless to say, the drive sits in my system as a holefiller only, and I don't even have the power cable plugged in.
I would have been fine if they said something COULD be wrong with the drive, but they "assured" me the drive was fine, it was merely a screw loose with the nut behind the keyboard.
I'll buy a bargain basement brand before I ever buy Imation (in fact, maybe that's what Imation is...bargain basement).
<long sigh>
