are these an upgrade to the stock 02 fronts?
Old Mar 13, 2003 | 06:10 AM
payyourtoll's Avatar
Default are these an upgrade to the stock 02 fronts?
The site recommends these for replacing 00-01 fronts, are they an improvement over the 02s as well?
click here for the specs if it helps.
Also, my goal is to have a single 12 running off an amp in the trunk, with upgraded fronts and added rears running off a strong hu. Am I going in the right direction here, or should I be looking to get something different. thanks
Old Mar 13, 2003 | 07:57 AM
mas's Avatar
mas
Nah, you don't need these. Your stock speakers (since it's an 02) would be better than these. Also, you already have tweeter pods in the car so gettting a set of co-ax speakers do not make sense.
Get the rears, add the sub and take it from there.
Old Mar 13, 2003 | 07:58 AM
jeffbrig's Avatar
The upgrade is going from a simple dual-cone driver in the 00 and 01 to a co-axial speaker. Dual-cone is pretty low-tech, relying on the small flyaway paper cone to flutter and produce higher frequencies. The co-ax has a dedicated tweeter to produce the high frequencies, a big improvement.
However, the 2002 already has a real tweeter, and its even better because its mounted separately high on the door. This is an improvement over a low-mounted tweeter because high frequencies are very directional. If you're going to upgrade the '02 speakers, buy a better component set that includes a 6.5" driver and the tweeter.
shortbloke
Nov 4, 2003 01:26 AM
reds2
Jun 30, 2003 10:09 AM
HARDtoTOP
Nov 2, 2002 03:31 PM
DJSang
Jul 19, 2002 09:52 PM
allen_j
Jun 28, 2002 10:27 PM
