For those with Amps where the spare use to be...
Old Sep 5, 2015 | 09:57 PM
GranPrix's Avatar
Default For those with Amps where the spare use to be...
For those with their amp on a custom rack where the spare use to be, how did you secure it to the car?
Old Sep 8, 2015 | 01:42 PM
stupkid's Avatar
When I made my rack I drilled a hole where the bolt to lock the spare tire down goes. Then I bought a shorter bolt from home depot and just bolted the rack down
Old Sep 12, 2015 | 01:33 PM
Sylvan's Avatar
I used the spare tire bolt with a hole in the middle of my rack.
Attached Thumbnails For those with Amps where the spare use to be...-img_1934.jpg   For those with Amps where the spare use to be...-img_1759.jpg   For those with Amps where the spare use to be...-img_1781.jpg
Old Sep 13, 2015 | 07:40 PM
GranPrix's Avatar
Thats exactly what i want to do! Do you happen to have the dimensions?
Old Sep 13, 2015 | 08:31 PM
Sylvan's Avatar
No I didn't write down any measurements
Old Sep 14, 2015 | 05:40 AM
UberDuper's Avatar
I'm working on mine now. It's pretty ghetto.
Basically just a board large enough to bolt my amp to it (RF Punch 800.4 so pretty big). Piece of 2x4 screwed to the bottom of the board. Drilled a hole through the 2x4 and cut the top off the spare tire bolt. So the board just sits on that bolt. I'll probably just use zipties to keep it from rotating. I'll put the trim back on so nobody will ever see my ghettoness.
Old Sep 14, 2015 | 11:29 AM
LoudMusic's Avatar
My amp is small enough that it fits inside the spare. I made a small plywood shelf that fits into the spare which I mounted the amp to. It's a hassle to get it in and out of the hole - not sure I recommend it If anyone is interested I'll take pictures.
UberDuper
Aug 28, 2015 07:54 AM
legin_k
For Sale
Feb 7, 2011 06:21 PM
r_duff
Aug 14, 2004 08:35 AM
Waterbug
Jan 9, 2004 09:01 PM
ruexp67
Jun 9, 2003 08:51 AM
