tips on removing door panel
Old Sep 29, 2001 | 12:37 PM
charlie's Avatar
Default tips on removing door panel
my driver side speaker is out, prob loose connection and need to remove the door panel...... can you talk me thru it? thanks
Old Sep 29, 2001 | 01:18 PM
Mike Schuster's Avatar
I posted instructions here
Old Sep 29, 2001 | 04:12 PM
jschmidt's Avatar
It's dead easy. You'll spend more time agonizing than doing it. If you're the least bit gentle, nothing will break. I found it easier to do by hand than with a trim removal tool.
Old Sep 29, 2001 | 05:38 PM
MacGyver's Avatar
See my webpage for instructions...
Old Oct 1, 2001 | 04:36 AM
Cortez's Avatar
It is pretty easy and the posted instructions are good. The only thing I would add is make sure you have a good quality phillps screwdriver for removing the screw that holds the black plastic interior trim piece around your door latch. My screws were so tight and the head stripped on the passenger side. I tried EVERYTHING to remove the screw. I finally had to take some snips and gingerly cut the trim out until I could get the panel off. What started out as a 20 minute project took an hour and a half. The replacement trim and screws were only $7. Whew!!!
Old Oct 4, 2001 | 04:42 PM
Utah S2K's Avatar
Check the MacGyver link....it has all the info.
Saki GT
Sep 12, 2017 07:47 PM
dlq04
May 22, 2012 07:39 AM
RL428
May 12, 2010 06:33 AM
Bandit_287
May 15, 2006 01:30 AM
