Removing the drivers door panel
Hi All,
My car has an annoying rattle coming from inside the drivers door somewhere so i need to remove the door trim panel to investigate..Is it easy to do? If so how many and where are the screws etc? I dont want to be forcing it off when theres a little screw hidden somewhere thats should be removed..
Many thanks..
Many thanks..
on the handle there are two clips to remove then two screws behind those and then a screw behind the door handle its hard to see.. then there is a clip on the front of the door panel. pop that off then from the bottom of the door grab the panel and it will pop off.. it feels wierd but it is way to easy...ive done it before swapping my all black door panels for red on black ones
