Tried Modifry's "Flash to Pass"...
Old Jun 29, 2004 | 07:51 AM
  #21
ATXS2K's Avatar
SUCCESS! Wired without jumper, button depressed at all times...garage goes up, garage goes down...of course when I hit the high beams!
WOOT!
-Jason
Old Jun 29, 2004 | 07:58 AM
  #22
modifry's Avatar
Honorary Member
^ Does this mean you got it figured out?
Oops - you got your update posted while I was typing.
Sorry guys, I've been busy and I knew S2ki was going to be down this weekend so I didn't check in.
The deal with polarity and connecting to the high beam wires is confusing. You do NOT swap polarity - you have to connect +12 from the high beams to + on the remote circuit board. I mentioned the part about not connecting the remote (-) to chassis ground because you must instead connect remote (-) to the high beam (-). The HIGH beam (+) has power all the time when the LOW beams are on (stupid Honda wiring), which would make the transmitter operate all the time if you used a chassis ground for (-) power to the remote.
So you have to connect both remote power wires to the high beam power wires, and observe polarity.
OK?
Old Jun 30, 2004 | 05:13 AM
  #23
ATXS2K's Avatar
AND DO NOT PUT A JUMPER ACROSS THE BATTERY TERMINALS!
When Modifry says to use the jumper, it for your button switch contacts, jumper those, or figure out a way to keep your button pressed at all times.
-Jason
91crxSi
Sep 15, 2013 09:52 PM
Refresh
Jul 9, 2012 06:55 PM
s2kvsall
Jun 9, 2009 07:56 PM
Bass
Jun 14, 2008 04:29 PM
KLN
Dec 31, 2004 12:48 PM
