Turbo Timer users, how do I enable keyless entry?
Old Jul 26, 2007 | 12:25 PM
s4play's Avatar
Thumbs up Turbo Timer users, how do I enable keyless entry?
I was going to post this in Forced Induction but think this is a better place with all you electronic gurus!
Basically I have a Greddy Turbo timer that I use sometimes to idle the car for like a minute. But right now basically I have to wait till the engine shuts off before I can walk away cuz my keyless entry won't work.
I remember on most cars there is a wire you have to cut somewhere to trick the keyless to thinking the engine is off so the doors can be locked via the remote FOB. I guess I can use my key but just curious what you guys have done.
thanks for any help,
rick
Old Jul 29, 2007 | 01:20 PM
REV.Group's Avatar
best to use a remote starter and manual turn it off with a long range remote due to the reason there's a chip in the key
Old Jul 29, 2007 | 05:44 PM
SoCalIsMyLife's Avatar
get a clifford. I can have mine alarm while it's running
Old Aug 3, 2007 | 02:59 PM
s4play's Avatar
guys you are missing my point I think.........
the turbo timer just keeps power to the Ignition wire after the key is removed so the "chip" factor in the is NOt an issue here as the car is already running!
I just want the oem factory keyless to lock the doors while the engine is running so I know there must be some wire to snip to trick it.
This has nothing to do with remote starts and I do NOT want one on a manual tranny car - way too dangerous - been there done that already.
rick
Old Aug 9, 2007 | 01:11 PM
s4play's Avatar
Found the answer thanks to another poster:
https://www.s2ki.com/forums/index.ph...ic=314036&st=0
rick
dales2000
May 23, 2011 06:38 PM
The Rev
Jul 1, 2009 02:06 AM
Chris_Lum
Nov 20, 2007 12:04 PM
indebt&lovinit
Sep 11, 2006 05:08 PM
S2X
Jun 19, 2002 08:54 AM
