vgs access
Old Aug 4, 2001 | 04:43 PM
Walter's Avatar
Default vgs access
Need help accessing the vgs unit. Where is it and how do I get to it? I need to tap into the tack line, Speed line ground and ignition to install a HUD.
Old Aug 4, 2001 | 04:48 PM
pellisS2k's Avatar
VGS? You dont have VGS.
Old Aug 4, 2001 | 06:26 PM
shaner's Avatar
You mean VSS? The vehicle speed sensor? It is a lead that comes off of the side of the transmission... it can also be accessed from the harnesses that plug into the instrument cluster. I used it for my GPS NAV system... It is a positive voltage pulse that varies (obviously) with speed...
Old Aug 4, 2001 | 06:48 PM
Walter's Avatar
I'm trying to install a Defi Heads up display. It calls for tapping into the wires coming from the Engine control unit (VGS-to the company) Unfortunately I,m unable to locate it or better yet how to get to it.
Old Aug 5, 2001 | 08:19 AM
shaner's Avatar
Walter,
Do they say what the VGS tap is for? What does VGS stand for? I can help you locate it if you can tell me what it does...
Also, I have a Defi heads up Boost guage (actually it's a Turbo Boost + Timer kit)... but it only shows boost in Torr not PSI... would you know if Defi makes a boost kit that displays in PSI?
It's annoying to always have to convert to a US measurement I can understand...
thePunkville
Dec 27, 2014 01:41 PM
DblAgnt
Jan 21, 2013 07:50 AM
jabbarahm
Nov 15, 2010 07:48 AM
Wahooz
Apr 5, 2008 07:17 PM
syellow
Nov 14, 2007 01:31 PM
