Viper 5901 - Control Center
Old May 2, 2010 | 10:55 AM
Elroy's Avatar
Default Viper 5901 - Control Center
The Control Center with the LED, Valet, and Antenna is, well let's put this way, I hate it. According to the installation instructions you can use an optional LED (8634) and Valet switch (8631) but since there are no additional port(s), how do you add them while maintaining the antenna?
J
Old May 2, 2010 | 07:55 PM
snipe99's Avatar
when you plug your antenna into the brain you use those ports. the white is for the external led an the blue is for the valet switch.
Old May 3, 2010 | 05:05 AM
2big4aS2000's Avatar
i put that behind the rear veiw mirrow on the glass, it is almost invisible in the car, but the led lights up the car so it is real visible,
Old May 3, 2010 | 05:42 AM
Elroy's Avatar
Snipe:
Cool but what are the other wires?
White and ? for the LED and Blue and ? for Valet.
2big4aS2000: I hate it as in it is FUGLY and would stick it on the diff if I could!
J
Old May 3, 2010 | 09:08 AM
the older models, had 3 different plugs, all on the one wire harness that goes to the antenna. now the newer ones the plug is just single, i guess you could cut it apart?
i would think you need 12+ ofr other wire on led
and ground - for the other wire on valet.
with it mounted up near top of winshield, behind mirror on passenger side a little, you really dont see it, i like the idea you dont have to put a hole in your car for a led or valet switch.
bhearn
Apr 13, 2017 07:08 PM
Paper Lawyer
Nov 29, 2016 02:49 AM
BobbyC
Oct 17, 2011 02:35 PM
sproket13
Mar 29, 2010 11:28 AM
Blk01S2k
Jul 15, 2001 10:37 PM
