vtec indicator
Old Jan 24, 2006 | 11:04 AM
datbird's Avatar
Default vtec indicator
Help!
I need an electronic guru advice. I plan to do the vtec indicator mod by using the LED in the cluster. Since I don't have OEM alarm. Can I use a relay to drive the LED or that too much current for the ECU to drive the relay? Can I use the counter with a LED if both are under 100 mA of current? It's a 05 s2k. Thanks.
Old Jan 24, 2006 | 01:51 PM
riceburners2001's Avatar
http://www.modifry.com/freebies/old/vtec/vtec.htm
Old Jan 24, 2006 | 04:00 PM
datbird's Avatar
thank riceburners2001,
I was hoping to use a relay to drive the led in the cluster, it's a negative input. I don't know how much current to drive a relay or any. Any professional help.
Old Jan 24, 2006 | 06:44 PM
Originally Posted by riceburners2001,Jan 24 2006, 02:51 PM
i was gonna do this mod and i went to radioshack today and they dont have the 50volt 1 amp diodes......
so i went to there web site, and couldnt find it there either...
wtf...where can i find these, "general purpose diodes rated 50 volts 1 amp (1N1001)"
Old Jan 24, 2006 | 08:16 PM
darkknight1999's Avatar
http://nowcomponents.com/item1/page.cfm/215
Old Jan 24, 2006 | 08:43 PM
Originally Posted by darkknight1999,Jan 24 2006, 09:16 PM
first of all... for the site.....BUT..
Minimum order size per line item is $500 USD. Please be aware, some international suppliers may have higher minimum order sizes (you will be notified).
Old Jan 24, 2006 | 08:57 PM
Holy Crap!! Yeah just ask Mac or Modifry... they most likely have a bunch anyway
Old Jan 24, 2006 | 10:32 PM
do u think modifry will hook me up??? should i just pm him or??
maybe ill wait till i get the shifter beeper thing.......but i wanna do the vtec mod now!!
Old Jan 24, 2006 | 11:42 PM
datbird's Avatar
Hey riceburners2001, I think he meant 1N4001 diode. Ask him to make sure.
Old Jan 25, 2006 | 12:06 PM
modifry's Avatar
Honorary Member
Oops! Thanks for noticing, I updated it today.
Just about any diode will work, just don't use anything identified as a "zener diode" or a "signal diode" or a "Germanium diode" . General purpose rectifier diodes, silicon diodes, or schottky diodes are fine.
If you get stuck I can send you some, but you might have to PayPal me $1. The stamp and envelope will cost more than the diodes.
Datbird - Yes the VTEC output on the ECM can drive a relay. You can use any low-current type, Radio Shack should have some though they are carrying fewer and fewer components these days. If you use a relay you don't need the diodes. They were there to keep the turn signal voltage from back-feeding and activating the VTEC solenoid. The relay will isolate the two circuits so you won't have that problem.
The other option is to use a transistor instead of a relay. Smaller and cheaper, (though it will require one or two resistors in addition to the transistor), but again it will eliminate the need for the diodes.
