vtec indicator
Old Jan 28, 2006 | 10:23 PM
  #21
hanggaw's Avatar
I wanted to do this mod. How do we find the security LED wire though? Anybody has done this yet?
Old Jan 29, 2006 | 12:43 AM
  #22
gt30r's Avatar
Originally Posted by datbird,Jan 24 2006, 12:04 PM
Help!
I need an electronic guru advice. I plan to do the vtec indicator mod by using the LED in the cluster. Since I don't have OEM alarm. Can I use a relay to drive the LED or that too much current for the ECU to drive the relay? Can I use the counter with a LED if both are under 100 mA of current? It's a 05 s2k. Thanks.
Why don't you just buy the vtec indicator gage from DoLuck?
Old Jan 29, 2006 | 10:30 AM
  #23
riceburners2001's Avatar
i just got done doing this mod, not with an LED, but hooked it up to the right side blinker. it was a B**** getting under the dash, and i, being 6' had to remove the seat. i havent tryed it out, but the blinkers are still working so
Old Jan 29, 2006 | 10:59 AM
  #24
vtec9's Avatar
www.digikey.com
No min order size
http://export.farnell.com/jsp/home/homepag...en_EX_DIRECTEXP
Farnell In one. Also no minumum, and very fast shipping.
I have ordered from both these places for various pcbs I have produced (I can hook you up with sweet deals on those if you want)
Old Jan 29, 2006 | 11:06 AM
  #25
viper_driver's Avatar
I did this mod a year ago to the right turn signal. It's awesome, why would you add another light? I followed Modifry's directions and had no problems at all. I liked it so much I did his high beam/ garage door opener mod too. Then, I even modified the top so it can go up or down at any speed. Thanks Modifry.
JASON
Old Jan 29, 2006 | 12:05 PM
  #26
JASON
no need to add another light. it was pain because the wires are so short and crap but still, almost free.
oh ya, THANKS MODIFRY!
Old May 8, 2013 | 04:07 PM
  #27
S2K9grand's Avatar
Hey modify I'm confused on the setup for the turn siginal vtech mod..... The directions are vague for the beganing of the process... How do I start hooking up the diods and to what wires or am I making my own wire harness prett much with the diods and the wires?
Old May 8, 2013 | 04:18 PM
  #28
S2K9grand's Avatar
Originally Posted by modifry
Originally Posted by datbird,Jan 25 2006, 03:42 AM
Hey riceburners2001, I think he meant 1N4001 diode. Ask him to make sure.
Oops! Thanks for noticing, I updated it today.
Just about any diode will work, just don't use anything identified as a "zener diode" or a "signal diode" or a "Germanium diode" . General purpose rectifier diodes, silicon diodes, or schottky diodes are fine.
If you get stuck I can send you some, but you might have to PayPal me $1. The stamp and envelope will cost more than the diodes.
Datbird - Yes the VTEC output on the ECM can drive a relay. You can use any low-current type, Radio Shack should have some though they are carrying fewer and fewer components these days. If you use a relay you don't need the diodes. They were there to keep the turn signal voltage from back-feeding and activating the VTEC solenoid. The relay will isolate the two circuits so you won't have that problem.
The other option is to use a transistor instead of a relay. Smaller and cheaper, (though it will require one or two resistors in addition to the transistor), but again it will eliminate the need for the diodes.
Old May 21, 2013 | 04:30 AM
  #29
Some87's Avatar
just make sure you follow the pictures that he posted too. you just need to make sure you have to 2 diodes wired up the right way. the striped sides of the diodes get soldered together to one wire and the other ends are soldered to there own wires. you do need to use your own wires on the diodes. thats what the 18" of 18 to 22 gauge wire is used for. the only thing i dont know is how long each wire needs to be so just look at where everything needs to go on your car before you solder up the diodes and see where you want the diodes to sit at.
Phill24
Feb 27, 2012 07:20 PM
Sabre
Jul 2, 2010 02:42 PM
jtpassat
Sep 3, 2005 11:39 AM
S2KJimmy
Sep 17, 2004 05:16 AM
warner
Jan 18, 2002 10:06 AM
