Weak Stereo Signal
Old Mar 22, 2005 | 08:21 AM
PilotChris's Avatar
Default Weak Stereo Signal
I have just recently been getting a much weaker stereo signal. It seems to have been getting progressively worse. A lot of the FM stations that I use to get are now getting some static in with the music and I don't even get any AM signals. This was not the case when I first installed my head unit 2 years ago.
I've checked the antenna cable behind the headunit. It's plugged in solidly. I've unscrewed the antenna near the trunk and rescrewed it back in, and have looked at the antenna base inside the trunk, and nothing seems out of order. I've also swapped the radio and verified that this problem still occurs with a different radio.
I did notice that while searching for an AM signal, if I grab the rear antenna with my hand, I could get one station to come in sort of well. But it falls back to staic the minute I let go.
Does anyone have any suggestions as to what the problem could be?
Thanks,
-Chris
Old Mar 22, 2005 | 10:25 AM
thetz99's Avatar
Try this thread. Since you swapped headunits and the problem persists, it is in the wiring somewhere.
https://www.s2ki.com/forums/index.php?showt...hl=am+reception
Old Mar 22, 2005 | 08:48 PM
darkknight1999's Avatar
Your gonna have to pull the HU and check the ant. plug on the back of the HU to see if it came out.
Old Mar 23, 2005 | 05:20 AM
PilotChris's Avatar
Thanks Thetz, this is exactly my problem! I'll check the AM power amp when I get home.
Thanks again
hipf
Jul 26, 2017 04:06 AM
pikkashoe
Dec 17, 2004 05:58 AM
WhataRide
May 21, 2003 07:03 AM
NeilW
Jul 12, 2002 01:49 AM
NeilW
Jul 11, 2002 06:20 AM
