What is better, active or passive?
Old May 23, 2013 | 11:57 PM
BlackFerret's Avatar
Default What is better, active or passive?
Hi chaps
Just installing more bits and bobs to my cars ICE and I've run across a confusing point (to my novice self)
My Pioneer 80 prs has 3 way active network or std network modes, now I have the alpine 4.100 amp which can only accept 2 rca inputs.
As much as I want to run 3 way active for the adjustability I can't because the high and mid range RCAs outputs can't both fit with a sub rca.
Am I best off just running std network and running one rca cable down the car and letting the amp do all the crossovers or can I still run two RCAs.
One for front speakers and one for the sub?
Cheers!
Old May 24, 2013 | 02:30 AM
lovegroova's Avatar
By using the sub outputs from the HU, you are effectively using the HU active crossover for the sub/mains.
What you can't do is use the HU active crossover for the woofers and tweeters, so you'll need to keep your passive crossover in place for those.
Best arrangement you can do is 2 sets of RCAs, one for the Mains and one for the Sub. There's no need to use any crossover settings on the amp as it'll all be done at the HU.
For full 3 way active you will need a 5/6 channel amp, along with two sets of speaker cables running from the amp to both the Woofers and Tweeters.
Old May 24, 2013 | 03:21 AM
That's was my original line of thought. Thinking I just got confused at the high/ mid bit in the instructions.
At the rate your helping me lovegroova I'm going to owe you biscuits!
Old May 24, 2013 | 05:51 AM
BLAQ&GREYs2k's Avatar
RCA splitters are cheap or a line out converter
Old May 28, 2013 | 07:56 AM
lovegroova's Avatar
That's fine if you want to bi-amp, but is no good for 3-way fully active.
solitarycheese
Jan 16, 2014 07:12 AM
hondavet
Apr 9, 2013 04:55 PM
cackasaurus
Oct 26, 2007 09:46 AM
crazylimey
Aug 27, 2004 12:37 PM
payyourtoll
Apr 4, 2003 11:04 AM
