What is a good tap-in?
Old Nov 19, 2002 | 12:25 PM
Luis's Avatar
Default What is a good tap-in?
I need to tap into a few ECM lines, but don't want to splice. Is this as good as anything or are there much better tap-ins? Supplier info will be welcome. TIA.
Old Nov 20, 2002 | 08:34 AM
WLAURENT's Avatar
My personal preference is to NEVER use these types of taps.
I prefer to strip the wire you need to tap into and then wrap the wire you are trying to connect around the bare wire and solder the connection. Use good quality (Brand name stuff) electrical tape to insulate your work.
Old Nov 24, 2002 | 07:31 AM
nEVERCLEAR's Avatar
if you do use those, I find it best to also use a zip-tie to be sure it stays tight, but when messing with any fuel or engine, better safe than sorry----Go with the proper method, solder.....
It would suck to get stranded for saving a few minutes on the install.
On a side note, I used the blue tap in for some lights I put in the footwell and the drivers side likes to flivker on and off even woth a zip-tie around it..
kasher_khan
Jan 22, 2018 05:05 PM
RedSunS2K
Oct 27, 2011 08:45 AM
Zgradis
Jun 6, 2009 05:50 PM
StockSH
Jan 10, 2006 09:34 AM
sfphinkterMC
Apr 15, 2002 10:01 AM
