12v Tap Question
Old Oct 23, 2011 | 09:14 PM
RedSunS2K's Avatar
Default 12v Tap Question
I'm installing my boost controller/boost/afr/oil pressure gauges which all require a 12V source.
I'm going to use this to spot to tap into. Is it possible to put all 4 devices onto the same tap? Or I be searching for 3 other spots to tap into? If it is possible to use one tap what size fuse should I use for the inline fuse?
Old Oct 26, 2011 | 04:36 PM
PUNCHIN-IT's Avatar
Sodder or use a butt connector to put all wires into 1 wire. Then you have one wire. Btw, you don't want to hit the constant. You want the accessory power source.
Old Oct 27, 2011 | 08:45 AM
street_ruler's Avatar
use the switched one. and use it as the "trigger" or signal for a relay that will turn those things on. then run a power wire from the batt into the cabin to the relay
kasher_khan
Jan 22, 2018 05:05 PM
GpWaP1 s2k
Feb 12, 2010 10:25 AM
StockSH
Jan 10, 2006 09:34 AM
Blurter
May 23, 2005 01:38 AM
Fiend
May 23, 2001 06:38 PM
