What Ignition type does S2K use?
Old Nov 19, 2001 | 04:59 AM
dhess's Avatar
Default What Ignition type does S2K use?
Are there any electronics gurus ouit there who can help me?
I recently purchased a kit to build shift lights.
It has the option to be built for cars that have a reluctor distributor OR for cars that use points, hall effect or have a low voltage input from the engine.
Which option should I build? The low voltage input from the engine version?
Should I use an input from the ignition coil or from the ECM pin A19 like stated in other threads?
Thanks in advance.
Old Nov 19, 2001 | 09:46 AM
jerrypeterson's Avatar
Use ECM A19. The S2000 uses four individual coils each mounted above the spark plugs.
Old Nov 19, 2001 | 04:25 PM
dhess's Avatar
Thanks. Is that a low voltage input though?
Old Nov 5, 2002 | 04:23 PM
Luis's Avatar
Did it work?
Old Nov 6, 2002 | 04:52 AM
dhess's Avatar
It does, but I ended up using a RPM test wire in the engine bay.
Its a loose blue, terminatd wire that is not attached to anything.
I think its near the master brake cylinder.
nazzri
Jun 3, 2014 08:11 PM
MegaTRon
Apr 23, 2014 05:55 AM
Dig8rs
Mar 1, 2013 11:25 PM
durtbikedude365
Nov 15, 2010 08:52 AM
S2KPUDDYDAD
Sep 11, 2006 04:42 PM
