What to mount amp on?
Old Oct 14, 2002 | 01:24 PM
S2KFanatic's Avatar
Default What to mount amp on?
I am going to install an amp in my spare tire & wanted to know what I should mount the amp on? Would plywood work or is there a more suitable material?
Old Oct 16, 2002 | 10:14 AM
S2KFanatic's Avatar
41 views & no one has an opinion?
Guess I'll use plywood!
Old Oct 16, 2002 | 10:29 AM
s2k330's Avatar
I put my amp in the spare tire and just put a lot of foam around it so I could get it out easily if I needed the spare. It seems to ride well even when I corner aggressively and also doesn't seem to overheat...my biggest concern. So far so good. It is a T class Blaupunkt 300 watt amp.
Old Oct 16, 2002 | 11:36 AM
amartin's Avatar
I put mine in the well in the trunk...
I bought a piece of plexi-glass from Homedepot... took the mat out of the trunk well placed it on top of the plexi-glass, drew a line around it, cut (slightly smaller) with a miter-saw and cleaned it up with a dremel... Mounted the amp with screws/nuts on the back. Fits like a glove.
If you get cleaver, you can then mount another piece of plexi ontop of it with "stand-offs", then put the mat back down.
-- Aaron
Old Oct 16, 2002 | 11:54 AM
2002S2000's Avatar
Here's an idea
Old Oct 16, 2002 | 01:01 PM
S2KFanatic's Avatar
2002s2000.....looks great! I don't want to go to the much trouble as I'm only adding a small amp so that I can hear my music w/the windows/top down. No subs.
Old Oct 17, 2002 | 09:58 AM
S2KFanatic's Avatar
Nevermind....ended up mounting the amp on the wall behind the gas tank, as the amp was to big to fit in the spare w/the retaining clip holding the tire in place. Oh well!
Old Oct 20, 2002 | 04:54 AM
HondaGuy's Avatar
Do u have a pic of that? I'm thinking about doing the same. Thanks!
Old Oct 20, 2002 | 11:59 AM
Never Quit's Avatar
I'd like to see pics too!
Old Feb 23, 2003 | 01:01 PM
b0mbrman's Avatar
Me too!
I'm extra curious as I've got *two* large amps to mount...
PAS2KNut
Jun 13, 2021 09:06 AM
tcho82
Jun 21, 2005 04:06 AM
LordMagnet
Nov 29, 2003 09:40 AM
ruexp67
May 27, 2003 09:55 AM
145
Sep 19, 2002 10:25 AM
