What speakers to buy
Old Apr 24, 2012 | 06:57 PM
etang789's Avatar
Originally Posted by 92DA9/06AP2
Looking to spend like 200 on components maybe 3 but not much more
Sent from my iPhone using Tapatalk
The speakers I recommended are within your budget, at around $250.
http://store.12velec...al-speaker-set/
Old Apr 25, 2012 | 04:44 AM
92DA9/06AP2's Avatar
I'll have to look again and re check prices
Old Apr 25, 2012 | 12:13 PM
What about the Polk audio components anybody use these and like or dislike? At 199 price is right
Old Apr 25, 2012 | 04:21 PM
Originally Posted by oth
There are very few if any speakers that are "drop in" to a late AP1 (with separate
tweeters) or an AP2. That said, most 6.5"/6.75" components will fit with relatively
minor work.
The issues are:
1) you'll generally need to substitute a spacer up to 3/4" deep for the stock plastic
speaker basket
2) you'll need to fit the tweeter where the existing one is, which may mean trimming
it, or removing a built-in grill.
3) you need to find a place to put the crossovers - many will fit behind the door panel,
but not massively oversized ones. If it's not in the door, you'll need to run at least
another set of speaker wires into the door.
Keep in mind that most aftermarket component sets will not be adequately powered without
a separate amp, so if your plan is just the headunit, get ones with a high sensitivity
(efficiency) rating, 92dB or greater.
The conventional wisdom is to replace the headunit before the speakers in an AP2, though
I can't personally speak about that - in an early AP1, you can probably improve the sound
by replacing the speakers with ones torn out of a clock radio...
HTH
I'm going to replace the hu once I can find one I like and then get the qube audio controls because I like those far too much to lose lol and an amp is a possibility but not anytime soon. I just want to hear music and not blown speakers but yes I want it to sound good
Old Apr 25, 2012 | 06:51 PM
etang789's Avatar
I have been using Polk Audio speakers for my wakeboard boat since 2005, have used their previous generation and current generation products. They sound ok but no where close to be as detail as the Imagine nor having the same amount of mid bass as the Imagines. But for their buy one get one free discount from crutchfield its a steal (works for me since I need 4 pairs) and being water proof for marine use were the biggest selling point. In short Polk sounds like where their price point should be, where as Imagines sounds like speakers in the $400 range.
Yea the headunit is the most important.
I think most of people here uses the Modifry DCI for the remote audio controls here.
Should also get the ebay speaker spacer and speaker wire adapter so you won't have to cut/drill in to the metal panel nor have to splice the wires at the doors.
hansai00
Aug 29, 2008 06:45 PM
Avionics86
May 17, 2008 08:49 PM
s2steve
Dec 10, 2006 11:33 AM
cpatel529
May 3, 2006 02:44 PM
JonasM
May 6, 2002 02:57 PM
