What sub enclosure are you using?
Originally Posted by lovegroova' timestamp='1406029200' post='23253984
Here's mine from the install thread https://www.s2ki.com/...st__p__16429072
Though since then I've switched the sub for a Type-R and now have an Alpine PDX-V9 fitted atop the fuel tank.
Given the locations of the kit, of course the tools are still in the car.
The whole thing sounds great, mostly because of the great quality HU, Amp and front speakers, with the Sub filling in underneath, like it's supposed to.
No I didnt build it. Got it from a local member. Wouldnt be hard to build. 10" sub. Since it doesnt utilize the whole space it has a lip around the top to hold it on top of the trunk floor. I'll try to find a picture.
Originally Posted by coop3422' timestamp='1406088748' post='23255431
[quote name='lovegroova' timestamp='1406029200' post='23253984']
[/quote]
Sorry, think I quoted the wrong person. Your install looks clean. Are your amps where the spare tire usually sits, or is it on the other side?
Originally Posted by lovegroova' timestamp='1406304144' post='23259267
[quote name='coop3422' timestamp='1406088748' post='23255431']
[/quote]
[/quote]
On top of the fuel tank, as mentioned at least three times now, and also as per my photos. Just the one amp now, of which there isn't a photo
Does having the sub upside down like that change the sound much or is it just for looks? I'm a bit of a noob with subwoofers, but I'm looking at my options.
Originally Posted by coop3422' timestamp='1406317724' post='23259595
[quote name='lovegroova' timestamp='1406304144' post='23259267']
[/quote]
[/quote]
[/quote]
I did some looking and saw what you meant. Is the sound deadening fine with the heat of the amp?
I've since modified the tray to stop it rattling which involved cutting some holes in it and adding sticky dynamat-type sound deadening material to it, so the insulation is a lot thinner.
Plenty of other people have amps mounted there (have a look at the installs thread, or have a search for "amp on gas tank") and I've not heard of any significant problems. A very helpful guy called "Oth" for example: https://www.s2ki.com/s2000/topic/398...stall-location
Obviously don't put an amp that has top mounted fans in there!
