What sub enclosure are you using?
Originally Posted by stupkid' timestamp='1409045148' post='23302081
[quote name='Pinky' timestamp='1408975263' post='23300527']
VERY tight space and would likely limit your ability to move the seat because of the shape of the seat pan.
If you look up the Aura Bass Shaker PRO I mounted one the the seat pan of each seat in my car. Takes bass to a whole other level. 12 in the trunk shakes the back the bottoms matched by the shaker making you think there is a much bigger sub setup. Still allows the movement of the seat on the drivers and some movement on the passenger but is more limited due to the tunnel bump. Being 6'2" seat says fully pressed up against the back of the rear wall 100% of the time.
Would the shakers be sufficient enough for bass instead of a sub?
Mine are mounted similarly to this but had to do a little massaging to get them to fit to the seat flush.
[/quote]
Thanks! Will look more into it!
