Where to buy speaker adapters
Old Aug 19, 2009 | 02:59 PM
brent_strong's Avatar
Default Where to buy speaker adapters
Just wondered where I can pick up a set of speaker adapters.
I know I could make some myself, but I don't have the tools to do workworking.
Are these any good?
http://cgi.ebay.com/6-Speaker-Adapters-00-...p3286.m20.l1116
Does someone sell MDF ones?
Thanks!
Old Aug 19, 2009 | 04:04 PM
philbert's Avatar
which speakers are you using? you can first try just cutting off the basket part of the stock piece.
Old Aug 19, 2009 | 04:09 PM
I need the 3/4" of space. Using Hertz HCX 165.
Old Aug 19, 2009 | 08:25 PM
lowrthnu2.2's Avatar
If anyone could confirm those work id go with them, or take the hit for us , if you use MDF youl need to weather proof them.
I wish some company would make so adapter rings like they do for Impreza's
http://www.iaperformance.com/product_info....products_id=247
Old Aug 20, 2009 | 06:05 AM
0verdrive's Avatar
They will probably work, but a few points to consider.
You'll want to make sure the inner mounting diameter of your cone will fit into the ring without modification. IIRC, the rings fit speakers with an inner diameter of up to 5.5". Any bigger than that and you will be sanding.
The other thing you want to consider is whether you care that your speakers are mounted into the door air tight. The adapters are constructed with two flat rings, separated 3/4" by those square posts you see in the pictures.
Old Aug 20, 2009 | 07:45 AM
Yeah, being airtight was a bit of a concern of mine, using these adapters.
Old Aug 20, 2009 | 05:53 PM
Anyone want to make me a set out of MDF? Please!?
Old Aug 20, 2009 | 09:08 PM
golfreak12's Avatar
I did a search for "speaker spacer" on Ebay and found a bunch of them, cheap too.
Old Aug 20, 2009 | 09:14 PM
Yeah, but I don't think any of those will fit the S2000 opening.
Papous
Jul 15, 2008 11:38 AM
rfullerton
Apr 18, 2008 12:22 AM
mic_crispy
Oct 8, 2007 02:28 AM
pjsub
Oct 20, 2004 03:10 AM
s2kdriver80
Aug 16, 2003 02:26 PM
