Where can I get trunk carpet?
Old Aug 13, 2005 | 08:38 AM
deanjones's Avatar
Default Where can I get trunk carpet?
I'm trying to make a back for the trunk to mount my amps on. Does anyone know where I can get carpet that matches the trunk carpet?
Old Aug 13, 2005 | 08:43 AM
jwa4378's Avatar
Pretty much any upholstery shop will have some, or will be able to order some. Might also want to check body shops.....they usually have a supplier.
John
Old Aug 13, 2005 | 10:20 AM
Jano's Avatar
The charcoal gray from www.partsexpress.com is both cheap and an excellent match.
Partsexpress
Old Aug 13, 2005 | 11:16 AM
Jano's Avatar
Not the best quality pict because of garage lighting, but the panel that the distribution block is mounted on is carpeted with the stuff I mentioned. The rest is factory. I think it's very close.
Old Aug 13, 2005 | 12:29 PM
deanjones's Avatar
Excellent!
Now, has anyone made a back wall for the trunk to mount amps on or anything like that? I took the spare out and I want that whole back area to be a wall and I want the middle of the wall to have a big hole in it. Like this:
[CODE]
Old Aug 14, 2005 | 08:00 AM
darkknight1999's Avatar
Make sure whatever carpet you order is no the backed style as it will be to stiff. You want NON-backed carpet so you can stretch it around the side and corners.
Old Aug 14, 2005 | 11:26 AM
jwa4378's Avatar
w/Darkknight.....if you get the backed type, it has a plastic like backer, that makes it a PIA to deal with. many bloody fingers!
John
Aren
Jun 14, 2007 03:43 PM
wantonetoo
May 30, 2005 12:30 PM
Evil G
Jun 3, 2004 07:27 AM
nEVERCLEAR
Aug 30, 2002 12:50 PM
