Where to get roll hoop covers w/ speakers?
Does anyone make aftermarket ones? Or do I first need to get the roll hoops w/ speaker mounting stuff from Honda ... THEN go buy some speakers and do the wiring?
Thanks,
D
Thanks,
D
Originally Posted by 240toS2k,May 12 2010, 01:35 PM
One optoin S-Pods, very pricey but IMO worth it. http://www.streetsmarttechnologies.net/
Or ... do folks union the L+R signals into one for the rear behind-the-head setup? If so, how?
D
Just to make sure you're clear on this before you find out the hard way:
You can't remove the roll hoop covers and put them back on the roll hoops. The halves are MELTED together with a hot wire and not clips or screws. No glue known to man holds them back together once opened.
If you pull the covers off some '06+ roll hoops and then pull your covers off, you'll be unable to install the covers on your car because they won't hold together. You will have ruined both sets of roll hoops and need to order complete replacement hoop+cover assemblies unless you like the nekkid hoop look.
Yeah, that super-strong glue or epoxy or whatever you're thinking of right now that would be perfect for the job? It won't work.
Regardless, mine have already been removed so I'm not "losing" anything there.
D
Originally Posted by DJT,May 12 2010, 04:54 PM
Hmm, I was thinking of something like that too. But it looks like the S-pods only give you one channel behind your head (a 6" and a 1" speaker) instead of stereo.
D
D
