Where should I mount the tweeters ?
Old Feb 1, 2008 | 12:29 PM
hkspwrsche's Avatar
Default Where should I mount the tweeters ?
Best place for space and sound? any best spots discovered?
Thanks
Old Feb 1, 2008 | 12:33 PM
hkspwrsche's Avatar
In case no one notices its for an 06 model that doesnt have the nice 03 style factory opening
Old Feb 1, 2008 | 03:04 PM
05S2KinClovis_CA's Avatar
I've got an 05 with factory tweeter openings in the door panel...doesn't the 06/07 models have the same door panel??? Triangular molding upper front of door panel. Tweeter mounts from the rear of the door panel.
Old Feb 1, 2008 | 03:07 PM
daktruckie99's Avatar
Did your tweeters come with nice looking covers?
If so you could mount them in the panel where the 02/03 mounts are.
If not I've seen them everywhere from the pillar, to the 02/03 spot, and on the door panel by the handle.
Anything above your knee's is best. My leg blocks the tweeter on my co-ax
Old Feb 1, 2008 | 06:55 PM
laguna2s2k's Avatar
Looks to me the stock locations are good, they are pretty high! That were Im puttin mine.
Old Feb 2, 2008 | 08:06 AM
hkspwrsche's Avatar
Do most fit behind the factory opening just fine? Is that as good a place for sound as any? Just above the knee blocking area is fine?
Old Feb 2, 2008 | 08:08 AM
hkspwrsche's Avatar
06/07 has the same but, I was referring to the 02/03 which is an easy factory swap and not available to the later models exactly
Old Feb 2, 2008 | 08:21 AM
hkspwrsche's Avatar
--- going for the Infinity Reference 6020cs into the factory openings it looks like. Still have the stock head unit but, will do that later
Anyone have experience getting these to fit into the stock openings? Will the tweeters fit behind the upper factory grille?
Old Feb 2, 2008 | 12:51 PM
mikey k's Avatar
Stock location.
Good position and easy to fit
Also means cross over can go in the door card with them.
At least that's what I have done in my last 3 S's
Apex1.0
Jun 10, 2014 04:32 AM
j8mie
Apr 18, 2007 03:03 AM
crxrex
Apr 20, 2006 01:11 PM
exelonman
May 6, 2004 06:35 AM
Element
Mar 23, 2002 12:17 AM
