Will this work
Old Jun 27, 2003 | 11:02 AM
reds2's Avatar
Default Will this work
I have some Polk GXR speakers with my '01 headunit. I also have Kenwood Passive crossovers and '02 tweeters. This is a temporary set-up. Can I even run the '02 tweeters with the co-axial Polks? Should I just leave the tweeters disconnected until I get a new head unit and maybe some component speakers. If I can do this, do I just hook up the tweeters and the speakers to the crossovers. I read something about the stock tweeters not being true tweeters and they split power from the stock '02 speakers. I think the crossover is just a small capacitor on the '02 tweeter.
Old Jun 27, 2003 | 01:03 PM
jeffbrig's Avatar
You're correct about the capacitor in the '02, which serves as a basic crossover. But that doesn't mean it's not a "true" tweeter. All component sets split power between a midrange and a tweeter this way, the only difference is that the crossover is packaged in a pretty plastic and lexan box.
Electrically, there's no reason why you can't just drop a coax into the lower door and leave it in with the stock tweeter. However, you'll probably find that it would be a little bright sounding, since you'd be running 2 tweeters on each side (1 in the coax, plus the '02 tweeter). Your best bet is probably to just run with the coax for a while, until you get can get a decent component set.
Old Jun 30, 2003 | 10:09 AM
Andy Kirk's Avatar
Hi:
When I installed my coax speakers in I just left the tweeters hooked up as they were so I have 2 tweeters on each side. I don't notice any particular brightness BUT I'm not sure I could notice it. There is a saying that by the time you are able to afford a top end audio system you are too old to appreciate it. Eh, speak up, stop mumbling
Andy
Blackdragon69
Apr 22, 2003 11:44 PM
GHS2K
Apr 4, 2003 08:37 AM
LostWaffle
Dec 27, 2002 08:48 PM
HARDtoTOP
Nov 2, 2002 03:31 PM
David1
Mar 6, 2002 07:48 PM
