Window issues
Old Dec 15, 2019 | 09:58 AM
WikkedTIki's Avatar
Default Window issues 01 AP1
Passenger window won't go up or down. Not even a click to engage the regulator. As a heads up, this car was gutted before I got it. So lots of electrical components are not plugged in. The previous owner unbolted the glass and has it held up by a 2x4. I'm not sure why he would if the regulator is still in there...
Steps Taken:
-Checked window lock switch
-Tried alternative regulator, neither work
- Made sure both window switches (driver and passenger) were connected. (The power side mirrors are not connected, the wires arent long enough for the custom door cards.)
-Checked fuses under dash, they are good.
Does the signal for the passenger regulator go an awkward route, as in if something else was unplugged the circuit wouldnt be closed? I'm stuck, any advice would be great.
Old Dec 17, 2019 | 01:34 PM
PureFunction's Avatar
i had the switch itself go bad one time so that is something to check. you can unplug the switch and just jump the wires on the plug to rule that out.
dank2k
May 15, 2018 07:00 AM
Stiggywig
May 8, 2018 11:20 PM
mark_k
May 7, 2018 03:50 AM
Mrsideways
R&C Parts For Sale
Jul 19, 2017 06:18 AM
GoKaart
Jun 23, 2017 01:08 PM
