wire to connect remote wire
sure, the easiest way would be to wire it to constant on instead of
the switched wire, then it would be on even if you took the key out.
this is how many (all?) Volkswagen products work. have to remember
to turn the radio off though...
Originally Posted by oth,Jan 4 2008, 10:57 PM
if the problem consistently happens when you turn the key, there is
no way the problem is a bad wire between the headunit and the amp.
Do any lights on the headunit flash momentarily when you turn the key?
to me that sounds like perfectly normal behavior if the headunit gets
power cut to it - the amp isn't supposed to turn on for a few seconds so
that the headunit can stabilize and you don't get a pop or anything.
what I don't know is why it has changed - I'm not sure whether the
radio should lose it's power when going from acc to on, maybe someone
else can do the experiment, my car is hibernating. In any event, it's
not a problem with the remote wire, and if the behavior has changed, I'd
still lean towards the ignition switch as the problem, though it seems minor
enough I personally wouldn't do anything about it until I had other symptoms.
i found the problem!!!
it was the wire i was using that was bad... i replaced the wire and now a am good to go
thanks for all your help guys... ill post pics of my new setup later
Originally Posted by Neutered Sputniks,Jan 3 2008, 01:44 PM
Guys, he has it wired to the remote lead from the HU at the current time. He's asking if he can wire it to another point b/c it's not staying on when the key is switched from ACC to Ignition.
