Wiring Doors
Old Oct 26, 2005 | 03:35 PM
DeViL's Avatar
Default Wiring Doors
Having a tough time wiring my doors right now... does anyone have any suggestions? Should I wire from the door or to cabin or from the cabin to the door? If I had fish tape I would be happier but as of right now i'm kind of stumped.
Old Oct 26, 2005 | 04:39 PM
jwa4378's Avatar
either way. Get a wire coat hanger. Straighten in out with a loop at one end. Run the loop end through both the Grommets (a little KY lube or WD-40 on the grommets / hanger helps IMMENSELY). Tie / attach the wire end to the loop, and simply pull back through. Might have to slit the grommet a bit with a razor, as they are kind of tight (but the lube might make it work without cutting).
You will probably cut yourself on the window frame....but it is always good to make a blood sacrifice to the install Gods .
John
Old Oct 27, 2005 | 05:30 AM
DeViL's Avatar
Thanks! I found that using unscented body lotion works like a charm I wasn't lubing it up earlier and it made so much difference after I did.
ayau
Aug 1, 2010 05:16 PM
futique
May 30, 2010 08:25 PM
sweetsleeper
Aug 25, 2005 05:25 PM
airbboi
Apr 8, 2005 06:14 PM
matrix
Mar 31, 2003 06:43 PM
