WIRING HELP...
Old Dec 11, 2005 | 03:49 PM
  #41
mr_grand_prix's Avatar
the amp as i can tell on this model doesnt show where the fuses are...i can find where one is...it is the fosgate 300s model...
Old Dec 11, 2005 | 04:09 PM
  #42
darkknight1999's Avatar
Does your amp look like this?
Old Dec 11, 2005 | 04:27 PM
  #43
no its an older model....
Old Dec 11, 2005 | 04:33 PM
  #44
What exact model is it? I feel like we're pulling at straws here...
Old Dec 11, 2005 | 04:36 PM
  #45
  #46
its the punch 301s
Old Dec 11, 2005 | 04:48 PM
  #47
jasonw's Avatar
So there's no fuse by the + terminal like in the first pic?
Where are you located btw?
Old Dec 11, 2005 | 06:38 PM
  #48
San antonio,tx
  #49
no there isnt a fse like the first pic
Old Dec 11, 2005 | 09:53 PM
  #50
littlerocket777's Avatar
Take your amp out of your car, bring it to under your hood and sit it on your air filter box. Take the 3 wires, Positive (red), Negative (black) and Remote (blue).
To test that the amp is getting power (and just for this purpose), take the blue wire and connect to the Remote terminal of your AMP. Screw it down.
Now take the other end of the Remote wire and twist it together with the Positive red wire. Now screw it down to the Positive terminal of your AMP.
Now take the Negative black wire and screw it down to the Negative terminal of your AMP.
Last step. Now you should have two loose (meaning not connected to anything) wires. A Positive and Negative wire. Take those ends and hold them onto the respective terminals of your car's BATTERY.
The amp does not fire up right away, it takes a few seconds. Keep an eye on the power light of your amp to see if it comes on.
Check your fuse on your amp if that doesn't work. Good luck.
