Wiring LED to E Brake to only
Old Oct 22, 2009 | 09:51 AM
Moddiction's Avatar
Former Sponsor
Thumbs up Wiring LED to E Brake to only
Well I want to install an LED into the interior door handles of my car and have them only come on when the E Brake is pulled so passengers can see the door handle and get out with attacking my door panel.
Would wiring it to the E brake wire allow this to work or what would I have to wire it to?
I am not too familiar with wiring and all. Know how to do it but don't know terms and stuff so please keep it simple lol.
Any help would be appreciated.
I got 5mm 180 degree viewing angle led's so should look good I think.
I am just going to drill a small hole in the door hadle hole cover or back or whatever you would call it haha.
Old Oct 22, 2009 | 09:53 AM
Moddiction's Avatar
Former Sponsor
Or if it was on all the time what would be the easiest place to tap into that would not stay lit when the car was off?
Old Oct 22, 2009 | 10:28 PM
bzyrice's Avatar
Maplights.. tap into those.. thats what i did in my TL.. I dont remember if the s2k map lights fade when you lock it..
If you wire it to your map lights they will turn on and off whenever they are activated with the main switch..
Scroll down to the bottom of the page to see my install: http://tl.acurazine.com/forums/showthread.php?t=715481
Old Oct 22, 2009 | 10:31 PM
Moddiction's Avatar
Former Sponsor
Well that would be on all the time or when the door is opened but the reason I am doing them is so you can see the door knob to open the door so would be pointless to come on ONCE you open it hahah.
But seems like the E brake when pulled creates a ground so that the light on the dash goes on so if I connect the ground to the E brake and then connect to the cig lighter or other power source like that I should be good to go I believe.
Old Oct 22, 2009 | 10:32 PM
Moddiction's Avatar
Former Sponsor
If I was putting lights in on the outside of the car then that would work great as they would turn on when you use the key fob to unlock the car.
boyguan
Mar 2, 2023 12:12 PM
travanx
Apr 1, 2010 11:44 AM
Moddiction
30
Nov 2, 2009 05:39 PM
Ludeboye1
Mar 25, 2009 09:59 AM
WLOCKARD
Sep 14, 2008 07:34 PM
