Would like to add White Rear Signal LED's
Old Jun 20, 2012 | 10:08 AM
Henwhee's Avatar
Default Would like to add White Rear Signal LED's
I want to add white signal lights to the rear but the bulb size is 1156A. The A stands for amber, and it's slightly different from the standard 1156 so that you don't accidently plug in a white light to the amber light.
1156:
1156A:
Does anybody know where I can find 1156A LED's that are white instead of amber? Or can i just grind off one of the tabs to make it fit?
Old Jun 21, 2012 | 07:10 AM
aphex4000's Avatar
http://www.js2k.com/index.php?main_p...products_id=64
Old Jun 21, 2012 | 10:13 AM
TPhong's Avatar
You should be able to find white LED's for the turn signals, but you'll need the resistor/relay to prevent the hyperblink. You also may want to check to see if a white turn signal is legal (vs amber) in your area/province. You could always just do an amber LED for the turn signal to get that LED effect.
T-Smac
Nov 8, 2012 03:55 PM
RylisPro
Oct 13, 2010 08:48 AM
timdon
Oct 1, 2007 12:27 PM
animeS2K
Jul 23, 2005 10:36 AM
