xm question
Old Jan 6, 2008 | 11:34 AM
feltf2's Avatar
Default xm question
my 05 has the factory xm antenna and tuner. I'm thinking about upgrading the head unit and wondered if I can still use the tuner and antenna.
Old Jan 6, 2008 | 07:27 PM
05S2KinClovis_CA's Avatar
Antenna...most likely if you stay with XM on your after market replacement.
Tuner...doubt it...it interfaces with the stock head unit and after market will be different.
Try to get a unit with XM tuner built in. Your antenna may hook up...but it will come with a new one anyway. All you'll need to do is contact XM and transfer your service to the new ID number on your new head unit. I believe this is still no charge.
Old Jan 7, 2008 | 05:30 PM
feltf2's Avatar
Thanks for your help!
Old Jan 10, 2008 | 02:29 AM
Bass's Avatar
the oem xm antenna uses an old two lead style connection whereas the new head units / xm boxes use a one lead style connection and the 2/1 adaptors do not work (oem ones don't fit)
what i did was gut the oem antenna and installed one of those x/m micro antennas inside of the housing so it looked oem
Rob2124
Mar 19, 2019 05:12 AM
S2020
17
Jun 13, 2016 02:10 PM
alexisthemovie
Jul 22, 2009 02:49 PM
spurfan15
Jul 14, 2009 05:19 AM
learnerspermit
Oct 19, 2005 04:05 AM
