Accessport for s2000
Old Oct 3, 2009 | 12:33 PM
  #91
don2007's Avatar
well the new GT-R wasnt supposed to be flash able, but cobb figured that one out. I think hondata is just lazy or wants you to buy something more expensive. Hondata FTL!
Old Oct 3, 2009 | 12:38 PM
  #92
FISH22's Avatar
Originally Posted by Mor.gan,Oct 1 2009, 02:03 PM
I'm aware of that but both products require you to connect the unit the OBD II Port.
Maybe, just maybe, the DBW S2000 ECU can not be flashed this way.
Actually, I think 06+ S2000s can be done like this. I think that's how Hondata does it(pretty sure they don't open up the ECU).
Old Oct 3, 2009 | 02:13 PM
  #93
Siggy's Avatar
Theyve done great things when i was researching the rx-8 prior to getting the S, VAFC seems like mehh to me, id love to see this happen
add me on the list!
Old Oct 3, 2009 | 02:22 PM
  #94
//steve\\'s Avatar
I was going to say the same thing about the gt-r. I know for a fact that car's ecu is significantly more complex than what we've got and Cobb had an AP out for that car not too long after it was out over here. I'm pretty sure if they wanted to they'd find a way to make this happen for our cars.
Old Oct 3, 2009 | 03:16 PM
  #95
gtg749m's Avatar
you can put my name down if they make one for ap1 model years.
Old Oct 3, 2009 | 05:14 PM
  #96
Jirzlee's Avatar
I will buy one!
Old Oct 3, 2009 | 05:43 PM
  #97
chubbys2k's Avatar
im in. yeah, i was confused too that they made one for everything else except S
Old Oct 3, 2009 | 06:18 PM
  #98
Sticky2k's Avatar
Old Oct 4, 2009 | 12:42 PM
  #99
Jacksparrow's Avatar
Here are some of the Accessport's features. I think there would be a lot more interest if members knew exactly what an Accessport did...
From Cobb's webpage for Civic Si:
"Unlike other tuning options, the AccessPORT is truly unique in its capabilities that go far beyond typical “chipping” or “reflashing” solutions. This is where the AccessPORT clearly stands out from the competition:
Simple Installation - Just about anyone with even the most basic of automotive knowledge can quickly and easily install an AccessPORT. No computers, wire cutting/splicing or tools of any kind are required.
Base Maps - COBB Tuning provides several preloaded maps for common power modifications. Each base map is dyno developed and rigorously tested in multiple COBB Tuning facilities across the country These tests cover the spectrum of altitude, temperature, humidity, octane and fuel quality variables to ensure proper calibration and performance wherever the car is driven.
Change Maps - Since all base maps and custom tune maps are stored in the AccessPORT, you can change maps any time you want. Switch to a race gas map for that extra performance at the track. Go to the Fuel Economy map for those long boring drives. Load the Valet map to keep revs below 3,200 when you drop your car off with the parking attendant. The Anti-Theft map does not allow the car to start, keeping it safe in suspect areas or during extended parking.
Performance - Turn on your own portable performance evaluation suite! Measure 0-60mph time, 60 foot and 1/4 mile ET’s and Trap Speed. Switch to Dynamometer simulation and calculate your vehicle’s horsepower and torque.
Live Data - Monitor OEM sensor data on-the-fly. Use the AccessPORT as an additional gauge to monitor a huge number of signals, like: Accel Pedal Position, Actual AFR, Baro Press, Coolant Temp, Fuel Trims (short and long), Ignition Advance, Intake Temp, MAP, Mass Airflow, Intake Valve Advance, VTEC Status and many more!
Datalogging - Onboard datalogging allows multiple channels of data to be recorded simultaneously for later review. This allows for analysis of current engine performance. Datalogs can be sent to professional tuners to provide additional power gains remotely through email!
Trouble Codes - The AccessPORT allows you to read engine codes to troubleshoot issues and potentially save you from an expensive trip to the dealership. Once the issue is resolved, clear the codes and turn off the check engine light.
Uninstall - In the event the car must be returned to the stock configuration, the AccessPORT can be completely removed and the ECU restored to its factory condition. Perfect for trips to the dealership."
Check out http://www.cobbtuning.com to see dyno's for many other cars the Accessport is already available for. We need a lot more interest! Tell your friends!
Should put this on the front page so people can read it
Old Oct 4, 2009 | 12:51 PM
  #100
lownslowneon's Avatar
I'd be down!
