AEM EMS - how do you check if it's using wideband or not?
Old Jan 24, 2012 | 06:53 AM
MB's Avatar
MB
Member
Default AEM EMS - how do you check if it's using wideband or not?
I have an AEM EMS V1 and UEGO lambda plugged in, but not sure if when it was mapped, it was left in open loop / fixed fuel tables, or if its using the UEGO for closed loop fuelling all the time.
If I go to "Fuel" and "02 Sensor Feedback", is it the tickbox in 02 FB control which tells you?
Old Jan 24, 2012 | 07:29 AM
jh4db536's Avatar
O2 feedback toggles it on or off
There is a 'hidden tab' called o2 feedback with all the parameters and 3d closed loop map by AFR
You can add a channel called o2 feedback in any tabs or logs and if you see activity, then it is active.
Sent from my T-Mobile G2 using Tapatalk
Old Jan 25, 2012 | 11:56 AM
MB's Avatar
MB
Member
Cool thanks
whitedxi
May 5, 2015 01:01 PM
gacklez
Aug 11, 2014 01:34 PM
CourageOO7
Aug 27, 2007 08:35 PM
ITBs2k
Nov 12, 2006 09:05 AM
AusS2000
Jul 7, 2005 04:38 PM
