Aem ems with new exhaust no bung for wideband
Putting a new exhaust on and there's no bung for my wideband and the 2 oem sensors. I have aem ems and was told/reading online that the stock o2's are useless once you have aem ems, is this true? Can I just remove one of the oem sensors and use that bung for my wideband?
I put the wideband in the test pipe, the angle of the o2 sensor bung on the Megan Header would have the o2 sensor against the body of the car and I didn't like that. Megan Header, 70mm Invidia test pipe, and 70mm Invidia cat back. Time for a retune
correct
how come you didnt just weld an extra bung to put the sensor in? im just wondering because aem widebands come with them to be welded, or you can drill a hole and use there band clamp design.
