AEM EMS rev limiter
Old Jul 13, 2011 | 03:17 PM
dan_uk's Avatar
Default AEM EMS rev limiter
in the V1 AEM it has "fuel cut" and I think "ignition cut" whats the best way to set this up ?
Old Jul 29, 2011 | 06:04 AM
wadzii's Avatar
Banned
set the ignition cut where you want the limiter to be, then set the fuel cut a few hundred rpms higher
Old Aug 4, 2011 | 02:04 PM
GEARHEAD's Avatar
Using a Series 2, I initially set it up with ignition cut 100 rpm before fuel cut.
This caused a nasty backfire at rev limit, which destroyed my cat-conv likely due to unburned fuel igniting in the cat.
I changed it to include a retard limit rev first, 100 rpm later fuel cut, 100 rpm later ignition cut and also used the Rev Limit Wizard to set it to Level 1-Medium Cut.
Now the rev limit is very soft with no backfires.
Old Oct 4, 2014 | 11:12 AM
dan_uk's Avatar
I was using the ignition cut and fuel cut 200rpm's later but now have an ap2 engine so I'm finding myself hitting my 8300rpm rev limiter more.
The problem is in corners on the track if I hit its upsetting the car, I figure I maybe hitting fuel cut?
I tried to set a limiter with retard timing and it seems like it maybe the solution, I guess it just pulls timing and creates a lot of unburtn fuel / heat in the exhuast?
Is it worth messing with the rev limiter wizard to change the limiter from soft > hard?
Old Oct 4, 2014 | 01:35 PM
wadzii's Avatar
Banned
set it to a soft cut for sure and make the separation between the ign retard and ign cut wider, that'll make it hit nice and soft so as not to upset the car.
mavrik
Jan 8, 2014 10:43 AM
camuman
Oct 1, 2008 06:45 PM
juice04
Jul 13, 2006 01:41 PM
fperra
Nov 3, 2005 04:30 PM
ukfinance2002
Oct 30, 2004 07:50 PM
