aem ems question
Old Oct 1, 2008 | 11:44 AM
camuman's Avatar
Default aem ems question
few nights ago i was setting up the 2 step, and heres where i am at now.
i have the switch always on, so as long as i am below 10mph the 2 step rev limiters should kick in. when monitoring in aempro, i see the switchover on the screen, but the limiter doesnt work. funny thing is if i get over 10mph i see the rev limiters change to my redline ones, and those work.
anyone else had this problem?
Old Oct 1, 2008 | 01:20 PM
CD7SirAccord's Avatar
Right now I have mine as:
Switch is always ON
2step fuel cut: 5300 RPM (Which I need to adjust, it's low and bogs the car down)
2step ignition cut: 12000 RPM
2step OK below VSS: 3 MPH
2step Retard Rev: 12000 RPM
That's how my tuner set it up, and it seems to be working
Old Oct 1, 2008 | 06:45 PM
camuman's Avatar
ok got it all figured out. it was the wizard settings, from soft to hard cut. i had it on 0, soft cut, which in lamens terms means no cut. raised to 5, medium cut and i am a 2 steppin fool
also had a problem with the decel setting, turns out i had it set to send fuel for every rpm under 9k on decel rofl. which meant never cut fuel on decel. changed back to 1400rpm, which is what i had it at with my stock injector tune, and its working again.
aen ems is bad ass, just gottta use the help button when your not sure what your lookin at.
dan_uk
Oct 4, 2014 01:35 PM
mavrik
Jan 8, 2014 10:43 AM
TJTURBO
Apr 22, 2008 06:29 PM
Spec_Ops2087
May 14, 2007 05:08 PM
fperra
Nov 3, 2005 04:30 PM
