AEM EMS Series 2
Old May 28, 2013 | 12:29 PM
siadam's Avatar
Default AEM EMS Series 2
When setting up the wideband controller, the data sheet they provide says run the WHITE analog into the Lambda input #1 Pin or Lambda #2 pin.
My question is, which one do you use? I still have my factory o2 installed, so should I use the #2 pin location?
Thoughts?
Old May 29, 2013 | 07:01 AM
siadam's Avatar
Anyone?
Old May 29, 2013 | 08:29 AM
indi00's Avatar
Doesn't matter.
The software allows for two wideband channels. If you spliced to the other, configure the AEMtuner to used that channel.
I spliced to C16. That'll be channel 1 in AEMTuner. Just unplug the factory O2 and wrap the sensor and ends with protective tape.
Old May 29, 2013 | 09:52 AM
siadam's Avatar
Originally Posted by indi00
Doesn't matter.
What I thought about doing, is unplugging my factory o2 and just wiring the WB into that,
Thanks.
Old May 29, 2013 | 10:28 AM
siadam's Avatar
For future reference:
http://www.aemelectronics.com/Images...%2030-6052.pdf
superfly77
Sep 11, 2016 04:46 PM
jb34304
Jun 5, 2010 04:21 PM
Spec_Ops2087
Oct 26, 2007 08:41 PM
GDM S2K
Jan 2, 2007 06:15 AM
XclusiveAutosports
Feb 8, 2006 06:01 PM
