AEM EMS v.2 fuel gauge?
Old Feb 23, 2016 | 03:11 AM
Chiung's Avatar
Default AEM EMS v.2 fuel gauge?
Does the fuel gauge run off the AEM or is it just wired directly to sender? '01 car.
Reason I ask is - ever since installation of KW SC and AEM, my fuel gauge never reads less than 2 bars and my low fuel light never comes on anymore.
Ran out of gas once.
IS the solution a simple re-calibration of the EMS or does the sender need to be taken out and physically tweaked?
Thanks
Old Feb 24, 2016 | 12:26 PM
CynicG's Avatar
Thanks
Did you upgrade the fuel pump too when the SC was fitted? I had a similar issue due to a poor fitting of the arm/sender when the pump was reinstalled, (it was actually floating in the fuel tank when inspected and not moving freely). I don't believe the fuel level goes through AEM at all.
Old Feb 24, 2016 | 02:09 PM
Chiung's Avatar
Yes, the fuel pump was changed when SC was installed. Thanks - looks like the sender arm needs to be tweaked.
Thanks
honda85
Jun 15, 2017 04:09 AM
Chiung
Feb 23, 2016 07:30 AM
