aem ems v1 vs aim solo dl
hi guys
recently bought aim solo dl and they provided me with a cable to connect to the aem ecu via rs232
made the changes required to the ecu
connected the cable to aim solo but nothing!
is there anything else i need to do to the ecu to start transmiting ecu data?
cable is fine talked to aim!
aim solo dl works fine!
if the there is anyone with the same set up any advice would be usefull!
here is the pdf to make the connection..http://www.aim-sportline.com/downloa...9+_107_eng.pdf
i propably have to enable the data stream so that the aem ecu can sent data to solo....right?
any input would be apreciated!
Did you configure the telemetry output in the AEM Pro software? See step 1 on the page below. There is a video link as well, the explanation for the aem pro software starts at about 1:30. Ignore the engine speed 50 part unless the aim dash is set up that way.
http://www.enoughlog.../initial-setup/
Just wondering though what changes were required to the ECU?
