AEM EMS V2 grounding issues
Old Oct 29, 2013 | 04:04 PM
S2kserry's Avatar
Default AEM EMS V2 grounding issues
a couple weeks ago i was driving on base and i hit a pot hole that came out of no where. 10 seconds after that i lost all power in my s2k and car shut off. i pushed it to a parking lot and it will crank but it wont start. after checking everything i switched in my oem ecu and it fired right up. i have read a couple other people that have similar problems but i havent found any solutions. does anyone know what this could be? i was told to check the grounds? does anyone know where they are? i heard one was behind the head but not sure which one it is. i am not fimiliar with the grounds at all so if someone could help me that would be greatly appreciated. pm or call/text 610 704 8722
Old Feb 3, 2014 | 02:57 PM
autofreak03's Avatar
hi have you solved the starting issue specially when warm/hot engine start? I'm having the same problem.
Old Feb 3, 2014 | 04:04 PM
chris_barry's Avatar
Does your AEM rattle. Some of the early ones had problems with a chip popping out of a socket.
mattie170
May 31, 2015 07:24 AM
Holeshot121
Oct 24, 2013 06:19 PM
bois2k
Jan 6, 2013 07:44 PM
AWWHITE s2k
Nov 2, 2012 12:50 PM
ArchAngel2K
Nov 11, 2009 08:36 PM
