AEM Infinity Power Issue
Old Mar 17, 2021 | 03:29 PM
Rajjuhh's Avatar
Default AEM Infinity Power Issue
Hello everyone,
Does anyone have a running S2000 with AEM Infinity?
For some backround information:
I have just swapped in a K24 and am trying to figure out why my laptop cant communicate with my new ECU.
I believe everything on my K side is correct but now I have no idea what to check in the S2000 side.
On my AEM Infinity harness have POWER coming to Pin 10 but NO POWER coming to Pins 63 or 68 which should be with ignition switch on.
I have checked all my fuses multiple times and I have no idea what else I can check.
When I turn ignition on, my laptop cannot connect to the Infinity, do not hear my fuel pump turning on, and TPS,MAP CPS do not have power. I believe something blew somewhere but that cant be the case since Ive checked every single fuse.
If anyone can help out please lmk!
Old Mar 18, 2021 | 07:06 AM
EOE's Avatar
EOE
Hey,
Have you pulled the negative battery terminal completely and let it sit for a few minutes? Basically to completely reset the Infinity ECU. That solved my issues where no matter how many times I power-cycled it with a key I couldn't access it via USB.
RAYZ-Ace
Jul 17, 2018 02:21 PM
c32b
Jun 14, 2017 08:41 PM
S2kfo
Sep 23, 2015 10:18 PM
