Aem wideband not reading in aempro please help!
Old Jul 22, 2019 | 10:24 AM
B1GW3AV3R's Avatar
Default Aem wideband not reading in aempro please help!
I would really appreciate anyone's help with this! I am getting an eTune done by Jeff Evans, but I can't get my AFR values to read in AEMPRO. I am using the AEM 1052U EMS, and I have a AEM X series gauge where I wired the white wire to the C16 which I cut going directly to the ems. The wideband gauge itself is working fine and operating perfectly, the only issue is in the AEMPRO software it won't read the AFR value at all, it just stays at a stuck number (16.7). I changed the AFR values to gasoline in the AEMPRO, I also changed it to recognize it as a external vs internal wideband since the 1052u has a built in. I am unable to do any logging or even complete the eTune without being able to log the AFR values. I've searched every forum possible to find an answer but can't figure it out. Anyone ever have this issue?
Old Jul 22, 2019 | 04:57 PM
B1GW3AV3R's Avatar
Anyone please?
Old Jul 29, 2019 | 03:16 PM
AP1Chief's Avatar
Your tuner should be able to guide you to the issue....... i do with my customers. if you wanna tune with me i can get you all squared away. im VERY familiar with AEM EMS just search some reviews. and tune ALOT of the S2ki guys here.
Old Jul 29, 2019 | 03:18 PM
B1GW3AV3R's Avatar
Thanks, he was able to square me away though. I didn't ground the brown wire since I have the X SERIES Wideband. I'm all tuned and good to go, I'll keep that in mind for next time though.
jdms2000f20c
Mar 23, 2012 02:27 PM
rio04s2k
Jul 17, 2010 10:06 AM
AusS2000
Sep 15, 2009 07:27 AM
PRS2K
Aug 2, 2006 07:54 AM
regmilla
Oct 6, 2005 05:47 PM
